It is currently Sun Jul 27, 2025 1:09 pm
PostPosted: Tue Oct 05, 2021 9:45 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I have all this mahogany or sapele and one block of walnut. I'm considering making a 2 or 3 ply block because the grain direction is all over the place on these. Looking for opinions.
Hutch
PostPosted: Tue Oct 05, 2021 9:54 am
I'm really picky about neck blocks and like the grain to be pretty even. Grain next to the sides should be aligned with the side grain direction. I haven't done a laminated neck block but I routinely use 1/2" baltic birch plywood for my tailblocks so wouldn't expect it to be a problem.
PostPosted: Tue Oct 05, 2021 10:19 am
State: West Somerset
Country: UK
I'm with Steve on this. I look for pretty clean grain and allign it with the side grain.
Laminating a few pieces will help but for such an important component I'd be reluctant.
+1 for ply tail block
Cheers Dave
PostPosted: Tue Oct 05, 2021 10:36 am
One thing to add: I would not want glue lam lines in the middle of a dovetail, obvious failure area if the joint is steamed open.
PostPosted: Tue Oct 05, 2021 12:54 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That was a good factor to point out. Though, one could use a glue that would hold up under the steam like TB3 or PU glue.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: SteveSmith (Tue Oct 05, 2021 1:08 pm)
PostPosted: Tue Oct 05, 2021 7:11 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Since the OP is showing end grain, I think the question is about degree of quarter. Most of my neck blocks are Honduran mahogany, and I don't think it makes much difference. Conventional wisdom says quartered should be the best, but that is countered by the argument that it is more likely to split at the base of the dovetail mortise. 45 degree grain would be more split resistant.
The only lamination I have done on neck blocks is a 1/4" thick vertical maple strip on the face. That guitar had a bolt-on neck, and the maple strip served to distribute the force of the bolt.
While some builders (including Prewar Guitars) do vertically oriented blocks (grain running from the top to the back), I prefer grain running side to side, ala Martin and Gibson. The idea of gluing the top and back to end grain is not my idea of the best approach.
Sent from my SM-G950U1 using Tapatalk
Users browsing this forum: Ken Lewis and 15 guests
